Electric Motor
Submitted by Mackfish on Tue, 2022-01-11 16:52
Hi, I am looking for any advice as to how best install a Water Snake Electric motor to a 4.75m Quintrex Coast Runner? I have purchased the optional mounting bracket. Cheers, Mack
.jpeg)
.jpeg)
Lefty 44
Date Joined: 04/12/17
Couple of rules
First I'm assuming it's a bow mount.
It will be a bit of a task putting it on your tub and hard to be definitive without seeing it in person.
I'll give you a couple of guidelines to go by.
1. They work best the closer to the center of the boat when deployed - Doesn't have to be perfect just as close as you can.
2. You don't want any part of it outside the line of your boat when stowed - It will hit the jetty
3. Looks like you will have to cut the bow rail as you want them sitting flat.
4. Battery - 125 - 150 amp hour will last you most trips depending on the amount of speed you use. I ran twin 100Ah for around 6 hours of use.
5. If possible, make it removable for long drives. Biggest killer of them is road vibration to the circut board.
Anything else specific - let me know and I'll try to answer.
Google is a great friend
Google is a great friend when it comes to this sort of stuff. There could be many ways to mount it . Looks it up and go for the best option .
ElGuapoPelagico
Date Joined: 15/12/21
every action
every action has an equal and opposite reaction. so you put minni kouta on bow and hav outboord on stern then you crush you boat like can VB
What do you call a fish with 20 eyes?
A FIIIIIIIIIIIIIIIIIIIIISH
squidvicious1
Date Joined: 22/07/10
Find a Ali welder to put an
Find a Ali welder to put an extra plate to 1 side of the bow, doesn't matter which side.like lefty said you'll have to cut 1 bow rail.
Or this mob in usa ' shuttleslide.com' do a mount so you don't need to get any Ali work.
beau
Looks like you'll have a
Looks like you'll have a prick of a time deploying it with limited access to the bow. Not even sure you have the room for it laid down when not deployed?
Mackfish
Date Joined: 10/01/22
Thank you
Thanks for the feedback.
I made a mount etc for
I made a mount etc for another member on the site, had to cut the bow rail but it did work.
