Distance to destination, help required.
Hi, I have a hds9gen2 and can't work out how to get the distance to destination (DTD) to show on the screen, have searched the manual and can't find instructions.
I posted the same question about a hds8 about 12 months ago but can't find that in the search bar.
Any help would be much appreciated.
Thanks in advance.
Tim's picture
Date Joined: 26/09/06
Old
Sun, 2015-12-20 11:39
 Heres the old question you asked
http://fishwrecked.com/forum/lowrance-hds8-gen-2
Dont know if its relevant to the touch
Marineboy's picture
Date Joined: 14/03/14
Thanks tim
Sun, 2015-12-20 13:06
just checked that out, must be different on the touch.
Date Joined: 28/07/11
 My Gen2 Touch came with with
Sun, 2015-12-20 14:44
 My Gen2 Touch came with with the latest software update found in the Gen3, so the instruction booklet didnt help me either. I did it by hitting the power button once, then selecting edit overlay, select Add, select Navigation and then you'll be ablt to select DTD from the drop down menu.
Marineboy's picture
Cheers bluedog
Sun, 2015-12-20 21:43
will give that a crack tomorrow
Date Joined: 27/05/14
Steering app
Sun, 2015-12-20 16:16
 I have the same system, I use the steering app on home screen,tells you dtd, time to destination, direction and all that info.
 I just hit a way point and
Sun, 2015-12-20 17:58
 I just hit a way point and then navigate to cursor and it shows the distance to in the bottom left of screen. Or am I missing something?
 Yeah you're missing
Sun, 2015-12-20 18:22
 Yeah you're missing something seakem haha!
Simo_'s picture
Date Joined: 13/11/06
 I've got the HDS7 and it
Fri, 2016-03-18 08:23
 I've got the HDS7 and it doesn't seem to have an option to have dtd on main chart screen. Any ideas?
Bring on April
Date Joined: 03/06/09
You got to go into Menu the choose Page
Fri, 2016-03-18 12:17
then select Add then use the drop down menu and go into Navigate (I think) then choose the Distance to Desitination from memory. I check and repost soon.
Simo_'s picture
 Mines a HDS7 touch screen,
Fri, 2016-03-18 15:35
 Mines a HDS7 touch screen, are these instructions for that or another model?
Bring on April
On a HDS Gen 1 & 2 (not touch)
Fri, 2016-03-18 16:10
Here's the step's as I've just checked them
Press MENU twice
Scroll to PAGE (using arrow button)
Use R arrow or ENTER
scroll to EDIT DATA OVERLAY (using arrow button)
Press ENTER
Press the ADD button along the bottom of unit
scroll to NAVIGATION using arrow button
Once highlighted use R arrow button to enter the Navigation menu
Scroll to Distance to Destination (or whatever Data option you wish) using arrow button
Press EXIT to finish adding
Press SAVE button along bottom of unit
If you don't save you're back to where you started.
Sorry, can't load pics of steps but if you PM me your email address I can send through
Pic added but in new topic
Fri, 2016-03-18 16:24
See topic Adding Data Overlay
 Legend Prego
Fri, 2016-03-18 18:44
 Legend Prego
Simo_'s picture
 Can't get it working on the
Fri, 2016-03-18 20:50
 Can't get it working on the touch, options are different
Bring on April
Marineboy's picture
Dtd
Sat, 2016-03-19 10:22
 simo, use bluedogs instructions mines a gen 2 touch and this worked for me.
mrwinta's picture
Date Joined: 14/01/10
 when on the screen you want
Sat, 2016-03-19 23:33
 when on the screen you want to edit put your finger on the very top right of the screen then slide down.. that brings up the settings menu for that page... cant remember from there but you will work it out i'm sure... I had to youtube that to find out how....
 NEVER PUSH YOUR GRANNY WHEN SHE'S SHAVING
