Diahatsu applause starting problems,
My sisters stops and starts all day in her business as house minder etc,,by the 3-4 stop the car can be hard to start a bit like a flat battery and cranks over really slowly, sometimes she has to rest it for 10 minutes and its fine,,last night she could not start it at all but we pushed started it first pop this morning,,it has EFI ,i am thinking something might be wrong with the alternater but i don't know why it only does it when itsd hot or why it started fine down the road by acts like its flats 1/2 later,,i don't believe driving puts a strain on a battery (tho its just occured to me she uses air cond on hot days)
Any ideas ?
Date Joined: 23/07/10
 Sounds like alternator is on
Sun, 2010-12-26 19:41
 Sounds like alternator is on its way out or the battery is on its way out not holding as much charge.
troy fuller's picture
Date Joined: 30/08/10
How hot is it getting? But
Sun, 2010-12-26 19:51
How hot is it getting? But yeah not enough power to turn the hot engine when everything is expanded. But if the car still starts then it's probably not the alternator. Your battery would die completely and not start at all.
Maybe use a voltmeter on it. see if the battery is around 12-14
cudbfishn's picture
Date Joined: 06/04/09
Take the car to any
Sun, 2010-12-26 19:57
Take the car to any battery/automotive place and they will test it for free. only takes 5 minuites.
Shorty's picture
Date Joined: 10/05/08
I don't think its the battery
Sun, 2010-12-26 20:07
I don't think its the battery at this stage,,all the mechanics are closed and now we have two more puiblic holidays so i am not sure if anybody will be open anyway?
My latest thought is it might be the fan belt slipping as it gets hot therefore not chargeing or gripping on the pulley ,she just mentioned a squealing noise so i am thinking i will check that out,,that drives the water pump as well,she says it got pretty hot today.
I can't see it being the battery but it was my first thought before,,
botti's picture
Date Joined: 24/04/10
Its the starter motor
Sun, 2010-12-26 20:51
its the starter motor or lead from the battery to starter motor if it still doesnt start with jumper leads when its hot its not your battery.
Shorty's picture
Will check all advice
Sun, 2010-12-26 21:26
Will check all advice tommorow thanks guys,,
