Detailing and trailer repairs
Submitted by Grey Ghost on Sun, 2015-11-29 21:46
Anyone got recommendations for detailing an 6.7m relatively new aluminium boat. Just bought it from interstate and appears not looked after very well. Needs a refresh.
Also electric hydraulic brakes not working. Recommendations for this?
Thanks for all suggestions
"Grey Ghost", 670HT Barcrusher with 150 Yamaha, based at Cockburn PBC.
Broady
Date Joined: 16/01/13
Re the brakes
Not much to go on, maybe battery needs a charge or replacement. Maybe give some more details on what's not working plus brand, and brake controller used?
epic restos and...
Date Joined: 22/06/15
bit more info would be good
bit more info would be good where are you located
Gav475
Date Joined: 16/11/11
trailer
platinum rv for the trailer. Mobile business, great young bloke shaun whos work is first rate. 0408133694
Grey Ghost
Date Joined: 12/10/15
More info
Sorry, Bar Crusher Easy Tow Trailer - plug looks good and electricity getting to it, however no activation of electric trailer brakes. Using a new Tekonsha P3 controller.
Detailing for boat - boat stored in Freo. Looks like previous owner didn't wash boat regularly plus lots of dog hair in cabin carpet.
roddo
Date Joined: 16/10/09
Some/most electric brakes
Some/most electric brakes need a hot wire going to them this is usually run through the reverse light pin in your plug just run it off your battery using a circuit breaker. If the car already has this it may have some corroded wireing on the trailer. Check the small battery on the trailer and the wiring that goes to it.
pull the breakaway switch
pull the breakaway switch first and see if system runs.
If it does then work backwards from there.
If it doesnt check breakaway battery and/or provide 12 volts to the breakaw3ay battery circuit.
This eliminates everything between the hyd unit and anything on the car itself.
After that it gets a bit more technical
Grey Ghost
Thanks guys. Battery good.
Thanks guys. Battery good. Wiring looks good and brake pedal activates pump but pump doesn't work when I pull the breakaway pin out. Someone looking at it today. Will give the reason in next day or two.
