correct dive weights
hi guys new to spearfishing just getting some second hand gear to have a go now just wondering if there is a method to working out the correct amount of weight to have on your weight belt or is it just whatever is comfortable any help would be much appreciated thanks joe
Swompa's picture
 I have scuba dived with
Mon, 2014-03-31 20:26
 I have scuba dived with ease, in t-shirt and shorts (a fortnight ago off rockingham) with two weights. Sunk like a brick.
milsey's picture
Date Joined: 22/08/07
 Depends what suit you have,
Mon, 2014-03-31 21:43
 Depends what suit you have, everyone is different but i like to be neutral around 5m. I dive mostly with a 3mm suit and wear a chest weight that I havent weighed but it would be simmilar to 3ish belt weights.
joe austin's picture
Date Joined: 06/02/14
 thanks guys
Tue, 2014-04-01 07:38
 thanks guys
Its a balance act
Tue, 2014-04-01 08:01
You dont want to sink like a brick, and you dont want to battle to get down.
I agree with the neutral idea at 5m roughly. When new it will take a little time to work out. If you are a standard size with a 3ml wetty start with 3 wts, 5ml 4 and work from there.
Get to 5m odd and see if you can just float around that depth without effort. Deaper down you will find you should sink a little faster, higher up float a little easier. But just a guide as everyone has to work it out for themselves.
thanks crasny very helpful
Tue, 2014-04-01 09:35
thanks crasny very helpful think I just gotta get out there and have a go trial and error I guess thanks again
Fisher Kid's picture
Date Joined: 16/10/12
im in the same boat just
Tue, 2014-04-01 18:03
im in the same boat just starting out spearfishing, i got a 3-5mm wtty and weigh around 85-90kg, im 6ft + and i use 3 3lb weights, maybe a tiny tiny bit too heavy, but with no air i just sink so my nose is out of water, will float up from 10m+ slowly though, sit still on bottom at 3m, i got mine ofr $11 each i think, or was it $9?
Fishing and catching are two different things. But i want to learn how to catch.
thanks fisher kid where did
Wed, 2014-04-02 09:01
thanks fisher kid where did you get your weights from mate....sounds like your a similar build to me so I will start there
