Carby bolts to engine keeps going loose
hi this isnt fishing related but im sure someone here can help me out
i have a brigss&stratton 2.5hp engine, and the screws/bolts that hold the carby to the engine keep  going loose and eventually falling out causing the engine to not run etc
is it okay to put some threadlocker on it such as locktite?
thanks
Date Joined: 27/08/09
Yep, but use a low to medium
Thu, 2010-10-07 19:23
Yep, but use a low to medium strength screw/thead locker. Anything too strong and you may have trouble getting them out again.
Date Joined: 23/07/10
If the bolts are not strong
Thu, 2010-10-07 19:27
If the bolts are not strong wouldnt use loctite, instead use the spring washers to keep tension.
Springs or stars
Thu, 2010-10-07 19:50
I would go the same as Dicey and use new spring or star washers and only then if they don't work use low stength Loctite.
wide open's picture
Date Joined: 24/12/09
yep
Thu, 2010-10-07 20:02
i got low strenght loctite so thats what im gonna use and springwshers if i ca nfind some haha
