car mechanic required sor
Submitted by fishcrazy on Mon, 2016-05-30 09:11
Hey all can anyone recommend a good mechanic rocko area pref mobile or otherwise that knows his stuff and reasonably priced dont want to get stuck with the ill guess and replace everything till i get it right kinda guys . Pajero nm has coolant leak sorta back of water pump valley area cheers craig
reece
Date Joined: 10/07/08
I get Neptune mobile
I get Neptune mobile mechanic (Macca) to do my 79series cruiser and Isuzu truck for my business. He's mobile and spot on
Any one free to help me pull my drum lines tomorrow?
z00m
Date Joined: 10/05/14
Leak
Is it the v6? According to google there is a pipe running from the back of the water pump for the heater system that has an o-ring that fails. 2 hours labour to change. If it is more than that it could be the water pump, backing plate or something worse. This was just from a quick search. At least it gives you some idea of what the mechanic should be saying and you can judge if they are on the level.
fishcrazy
Date Joined: 27/01/07
pajero
Thanx guys does anyone rate lubemobile?
Dale
I got a quote from lubemobile to do a cv joint on my outback and they quoted $800 and said it would take all day, bit steep I thought since I know my old Subaru mechanic back in Busso would have the old one out and a new one back in in 40 minutes max, so needless to say I never went with them.
eziliving
Date Joined: 30/12/09
I've used Neptune before as
I've used Neptune before as well and great service and good rates. Will be using him again.
