boat trailor wheel bearings
Im towing the boat up north in a few weeks and want to get the bearings done on the trailor, Ive never done it since Ive had the boat. Can anyone advise me on where to take it to get done and about how much it would cost. I live in the Kwinana area.
Simon
Bring on April
We use rockingham boat
Sun, 2008-11-30 11:15
for all our repairs but it does not need to be a boat place any mecanical place can do them . I do our own ,bearing are only about i think $30.00 each set one per set.  the labours is what costs money .
RUSS & SANDY
BQ544's picture
Date Joined: 22/10/06
Wheel bearings
Sun, 2008-11-30 11:19
Simo,
Pretty easy to do them yourself. I do mine once a year. And still on the same set of bearings for six years doing alot of k's.
Just take the hub off, take out the bearings and completely clean all the old grease out using a parts washer. After you clean them inspect them and then clean the degreaser off by washing them in gear oil. Get yourself a bearing packer and a grease gun. Bearing packers about 10 bucks from Mal's or Super cheap. Then pack them with Mobil SHC220 synthetic grease. Reassemble making sure your back seal is good. Then you refit them don't over tighten them, they need a bit of play. Dont forget your split pin!
Simo_'s picture
Date Joined: 13/11/06
Im not the mechanical type,
Sun, 2008-11-30 11:35
Im not the mechanical type, so might get someone to do it for me.
Bring on April
roberta's picture
Date Joined: 08/07/08
Simo neither is Bob
Sun, 2008-11-30 18:20
 did his three years ago, plus we have two spare hubs complete with new bearings, greased up.  Bearing buddies also, before we go to Leeman Bob pumps grease in, then next day (cool) in Leeman pumps then again, we leave to come home repeat procedure.
SPEWIE LEWIE
Ginger Tablets Rock
mako magic's picture
Date Joined: 03/08/05
Dont get me or Paul G to do
Sun, 2008-11-30 12:41
Dont get me or Paul G to do it or you will need 2 sets of bearings to get it right lol.
After the first (wrong)  one done as it was late and we were so tired, the next one was easy, just follow instuctions and make sure things arent put in back to front lol
PH:9248 3800 unit 3/11 Alexander drive Malaga
Date Joined: 22/02/07
pm sent     I wish I had
Sun, 2008-11-30 13:00
pm sent
I wish I had an emo lawn so it would cut it self
harro's picture
Date Joined: 07/02/08
u got bearing buddies?
Sun, 2008-11-30 17:02
they will help
 :::: Bass Hunter ::::
HuggyB's picture
Date Joined: 03/08/08
you should learn how to do them
Sun, 2008-11-30 17:20
Might be tough to "get them done" if they fail on you are 200km from the nearest town - just because you are replacing them doesn't mean they can't/won't fail. You need to be fairly self sufficient in said circumstances so that means having a spare set and knowing how to change them in the event you need to.
Feral's picture
Date Joined: 01/11/06
using bearing buddies or
Sun, 2008-11-30 17:35
using bearing buddies or dura-hubs will help a lot .... im trying the dura-hub system this year to see how they go (so far so good after 5 mouths)
Bart-Man's picture
Date Joined: 26/09/08
Yep have ago
Sun, 2008-11-30 18:18
If you can't do them (which isn't hard) at least watch who ever does it, as huggy said if your stuck somewhere be nice to have some idea, buy an extra set and keep in your travel kit. At least if you have them and are stuck some one will know how to change them out.
good luck.
have to agree there
Sun, 2008-11-30 18:34
We had one go in exmouth this year it would have put us out of the water for a few day had i not know how to do them and also a guys who had a spare set luckerly that fitted our wheels . but from now on i am carring 4 spare sets as you just never know when they are going to go on you .
RUSS & SANDY
Simo_'s picture
ok I will give it a go, Ive
Sun, 2008-11-30 18:44
ok I will give it a go, Ive had a few ppl off here say they will help me out. Cheers guys.
I have bearing buddies, does that make it easier?
Bring on April
Date Joined: 04/06/07
I remember a few years back
Sun, 2008-11-30 18:50
I remember a few years back at the Rocky Offshore camp at Jurien and some head lights coming towards me around midnight, wasn't that you Russ?Laughing
Ha ha ha yeah but that what the whole wheel
Sun, 2008-11-30 19:12
that had come off not just a bearing gone ., All the studs had come undone *LOL*
Thanks for that reminder Jason Laughing
RUSS & SANDY
Sorry to remind you of that
Mon, 2008-12-01 03:58
Sorry to remind you of that one, we had a similar experience travelling to Leeman once but we didn't realise the wheel had come off until we stoped for something to eat at the Road House, while walking back to the boat and trailer after a feed noticed one of the wheels missing with the axl hanging there just above the pavement, SHIT!! out with the tools.
Goatch's picture
Date Joined: 03/07/07
From my own
Sun, 2008-11-30 19:08
personal experience the bearing buddies will help with minimising breakdowns if used right , by pumping some grease in before you go you lesson the chance of any salt water entering the bearings causing failures , I've run them for 10 odd years and have never had a failure or had to replace a bearing because of apparent wear . A couple of mates have had failures with the oil filled hubs(dura hubs) when on long trips a seal fails you keep motoring on down the road unaware that you have lost the bearing lubrication only to pull up at the next servo and find youv'e got a wheel about to fall off and a damaged stub axle . Bugger . Stick with the Bearing Buddies IMO
Does a one legged duck swim in an eliptic circle
