boat stalls
hey,
i have a yamaha 2 stroke outboard and i have a problem with it stalling at idle.. it runs really well when moving but... like to know what may be causing this?
Lamby's picture
Date Joined: 04/08/09
What year, what hp, then more
Sun, 2012-03-18 20:18
What year, what hp, then more questions can follow.
Jeez I love a vague thread
zak_fish's picture
Date Joined: 27/12/11
2001, 90hp mate
Sun, 2012-03-18 20:28
2001, 90hp mate
Date Joined: 27/12/06
Fuel line
Sun, 2012-03-18 20:47
Could be a number of causes, most common is probably an air leak in your fuel line/system even the clip that goes onto the motor. Check it all out only needs to be a very small hole
zak_fish's picture
ok cheers, ill suss it out
Sun, 2012-03-18 20:50
ok cheers, ill suss it out tomorrow
Reefmonkey's picture
Date Joined: 22/09/08
Had the same problem a few
Sun, 2012-03-18 20:52
Had the same problem a few years back with a 70hp 2stroke, ran fine at speed but couldn't hold idle and would stall. dont know much about carby's but it had a very small salt crystal sitting on the pin??? (maybe) that was slowing the fuel flow at idle. took it into the shop as motor was due for a service anyway didn't cost much extra only about and extra hour or so of labour. could be a bit of dirt or something in the carb.
 Dave J.
silly's picture
Date Joined: 02/01/09
try looking for the idle
Sun, 2012-03-18 22:01
try looking for the idle control screw (usually has a spring on it), adjusting this screw might fix the problem
 best not do that till you
Sun, 2012-03-18 23:37
 best not do that till you work out if its something wrong. otherwise you'll just be chasing ya tail.
first thing id be looking at is plugs. pull them and check colour, should be a tan colour
