Boat paint removal
 Hi All, what would be the best method to take a painted Ali boat back to bare Ali and to leave it unpainted and would you have to finish it off some way so it looks ok. Cheers
surge's picture
Date Joined: 17/08/09
 paint stripper,remove all
Sun, 2018-01-07 11:13
 paint stripper,remove all the paint and if you want you can buzz the ali back with 400 wet on a sander and clear coat over the ali will come up mint,i have my own spray painting panel beating buisness in rockingham
 Is there a certain brand?
Sun, 2018-01-07 13:35
surge's picture
 of paint stripper?not really
Sun, 2018-01-07 17:24
 of paint stripper?not really mate they all work preety good
 Ok mate cheers, I just
Sun, 2018-01-07 18:24
 Ok mate cheers, I just thought to remove marine 2 pack you'd need something specialised.
Date Joined: 27/06/11
Sun, 2018-01-07 18:39
 so  it would be better than some type of blasting the paint off as it is a reasonable size boat
surge's picture
 if you blast it you wont get
Sun, 2018-01-07 20:40
 if you blast it you wont get a smooth finish,it will pit the ali...
Date Joined: 27/12/14
will the paint stripper break
Tue, 2018-01-09 18:32
will the paint stripper break down the all filler? i know my boad has alot of it almost 3mm in some places.
Date Joined: 21/11/15
I just did this between xmas
Tue, 2018-01-09 21:36
I just did this between xmas & new year (all those windy days, thought I'd get into in while on break from work).
Mine had a crappy diy fitout, I'm doing a new fit-out so full strip including wiring. Found original mustard colour done prior to fit-out, then had white rolled & brushed after fit-out, looked like crap.
Did a lot of googling/reasearch re stripping, read other forums with similar Q's, majority response was to save the stress & pain, get it Soda Blasted!
Well with most tradies/factories etc also on break I did'nt have that option, worried about certain chemicals on ali I bought 4lts of paint stripper from a specialist paint supplier (automotive etc) on the Saturday, spent all day/dusk on it, all 4ltrs, only looked half done.
There closed Sunday so I grab a couple of cans of spray from Supercheap, barley touched it.
Off to Bunnings, 4ltrs of Polystrippa, another full day applying, scrapping, power washing etc & I'm still not fully satisfied with the result.
So with hindsight, In the end when I add up cost of stripper, water, elec, back & forth to shops, burning to skin, sore hands etc etc etc, I would have waited for everyone to go back to work, spent ~$400 to get it Soda Blasted while I did something else.
