Boat fuel
Hi, due to work commitments, oversea holidays and shitty weather I have been unable to use my boat for about 3 months,I'm hoping to get out on Thursday Arvo for a snapper sesh, with the fuel sitting there for that long is. There anything I should do before using it? Have about 80L in a 120L tank,does it go stagnant or will it be ok?
Sorry mate
Tue, 2011-08-02 08:33
With that Avatar name no help from me coming forth!!!!!!
Nah mate, should be cool, check the fuel filter, top her up and Bob should be your Uncle!!
Neels
Gricko's picture
Date Joined: 09/07/10
disagree with that name must
Tue, 2011-08-02 09:04
disagree with that name must be a good bloke, 3months old fuel wont be a problem
All this working keeps getting in the way of fishing!
Daisy's picture
Date Joined: 24/01/08
Should be good as mate, have
Tue, 2011-08-02 09:26
Should be good as mate, have to watch fuel in plastic tanks though, the only thing you need to watch maybe is condensation, alttle bit of metho should clear that up or if you have a water trap type water filter you can pour it off.
Date Joined: 02/01/10
If my fuel is getting old, as
Tue, 2011-08-02 10:33
If my fuel is getting old, as my tinnie would be now, I just top it up with premium, to boost the octane a bit.
Date Joined: 03/09/10
6 mths
Tue, 2011-08-02 11:06
is usually about the time it takes before fuel starts to lose it's octane strength but if kept cool during storage this can be a bit longer.
snappermiles's picture
Date Joined: 05/11/10
as previously said
Tue, 2011-08-02 11:20
just top it up! then it will be fine!
Date Joined: 06/07/11
Only problem might be if it was premix 2 stroke
Tue, 2011-08-02 18:57
Not that I know many onboards with premix 2 stroke, but if it was then you'd probably get separation of oil/petrol mixture, that might be a pain
Anthony Hall 87's picture
Date Joined: 09/01/10
Only thing I would watch is
Tue, 2011-08-02 19:11
Only thing I would watch is condensation in the tank, litre of metho and top it up.
Clear fuel filters are also the way to go so you can drain off any water. The age of the fuel wont be a problem though.
Tight lines to all :)
AllBoatsChandlery's picture
Date Joined: 17/07/10
Should be ok
Tue, 2011-08-02 22:57
But either metho or Quicksilver has a product called DriFuel (now called Quickare no1) which takes out the water, maximizes engine performance with all grades of petrol, helps control corrosion, gum and varnish build-up. Helps control moisture and corrosion problems associated with non-ethanol fuel, cleans varnish and gum deposits from fuel lines, tanks, carbi's and injectors, intake valves, and spark plugs and keeps fuel fresh between fill-ups – up to 3 months. They have 3 products in the line up step 2 is Quickleen – For use as needed throughout the boating season and 3 Quickstor – Add to fuel before long-term storage of your engine which you can use next time you know you wont be using the boat for a while.
"There's no business like boat business"
spinksy's picture
Date Joined: 06/10/10
Was told the other day
Wed, 2011-08-03 06:30
That fuel these days starts to break down lose octane  around two weeks..... Who knows..  i would put a bottle of stabil in just to be sure.
collin g wood's picture
Date Joined: 18/04/11
thanks for your info, will
Wed, 2011-08-03 07:23
thanks for your info, will get some drifuel just to be on the safe side.
