Boat fittings and Pop Rivet rouble
In what I do certainly not an expert with rivets. Once a boat fitting perishes, how to you get the rivets out. I have some ideas but dont want to injure the structure without some expert ideas.
Neels
Sorry Trouble
Sat, 2010-09-04 10:31
Neels
Date Joined: 27/08/09
Drill them out using the
Sat, 2010-09-04 11:03
Drill them out using the same size drill as the pop rivet stem. If unsure go a little smaller on the drill size, and increase as needed. Use the hole in the head of the rivet as a guide to centre the drill bit.
If you're not confident, put a couple of pop rivits in a scrap peice of metal and have a practice run of drilling then out before you tackle the real job.
Date Joined: 23/07/10
might also want to note dont
Sat, 2010-09-04 11:11
might also want to note dont drill out too many at a time, do a couple at a time that way you can do it alone and it wont go out of shape.
definately got to drill them
Sun, 2010-09-05 22:48
definately got to drill them out but the only prob is there will be a part that will fall inwards. unless you have access to the cavity behind they will stay there forever. its not a hard thing to do but just take it slowly so you dont damage  the surrounding area
Cheers all
Mon, 2010-09-06 13:08
Done and dusted. Now if only I can get the bloody trucks on Dampier Hwy to stop blowing the Bimini off. Yesterdya dropped the lot and still had trouble with the ken trucks.
Neels
