best glue for sticking marine carpet to ply wood
Submitted by brg on Tue, 2010-08-31 18:25
just wondering whats the best glue to use for marine carpet to ply? was standing in bunnings for half an hour looking with no one around to help.cheers
flangies
Date Joined: 11/05/08
I'm sure others will have
I'm sure others will have some opinions on this but i have found contact adhesive to work quite well, you just apply on the plywood quite generously, wait for it to start to set then stick the carpet on, Strong and even connection.
fisho-ron
Date Joined: 26/09/09
kwik grip mate, works better
kwik grip mate, works better if you can spray it, but also can be brushed.
big john
Contact
As Flangies says, good old contact works a treat.
Only difference with me is I sealed the ply with varnish first, and then applied contact to both the ply and the back of the carpet. Once they both get tacky enough not to lift off on your fingertips, join them together.
luke t
Date Joined: 22/02/10
agree 100% with big john, in
agree 100% with big john, in that if you dont seal the ply youll eventually end up with the ply falling apart (regardless of what ply youve used)..
if you want to do it right, an epoxy sealer or varnish is best.. (a few coats of evidure would be my preference)...a contact cement like kwik grip is relativly cheap and best applied with a v-notched trowel (if your not able to get a sprayable type)
put it on bot surfaces THEN LET IT DRY before you stick it (youll really only get one good shot at it coz that stuff sticks like S#!T to a blanket )...
Faulksy
Date Joined: 05/05/10
I used liquid nails and it
I used liquid nails and it worked well
brg
Date Joined: 31/12/09
cheers guys couple of good
cheers guys couple of good options there
wazzbat
Date Joined: 19/01/10
How would exopy go?
How would exopy go? After you seal the ply first. I suppose you need something that will not rot in the wet, salty water. I reckon liquid nails might break down after a while.
kempy
Date Joined: 28/05/09
we used stainless steel
we used stainless steel staples
Sikaflex
Try using Sikaflex, it shouldn't need to be a complete coverage just round the edges with some extra squiggles and wiggles to hold down the central area. It is designed for marine use and will stick to almost anything.
dannyboss
Date Joined: 07/08/10
mate im a carpet layer and i
mate im a carpet layer and i would suggest using an indoor/outdoor pressure sensetive glue, you can get it at any carpet supply shop, or bunnings but will be more expencive.
mightymouse
Date Joined: 25/08/08
Hi brg, Im a
Hi brg,
Im a marine/upholster I can give you the right glue if you want a small tub
Im in malaga PM me if you want to swing past
MarkM
Date Joined: 24/05/09
MM
What's it called and where can I get it or something similar?
Cheers.
daZa
Date Joined: 17/12/07
bostik contact adhesive
Im a shipwright and its the only way I would do it (contact adhesive)! Just make sure you dont spill fuel on your carpet!!!!it wiill disolve the glue!
