Advice on what fluid to run in a wet box.
Submitted by Blank Cheque on Fri, 2009-04-24 11:26
I have been talking with a couple of guys around home of late on what fluid is best to run in a wetbox. There have been several suggestions. Has anyone experimented or any advice please ?
Any help would be greatly appreciated.
Wet box
What is a wet box? Or am I the only one here who doesn't know.
Blank Cheque
Date Joined: 28/03/09
Thanks for asking some may know it as something else.
Its a box/Tube that is moulded to the inside of the hull. The tranducer is then mounted to the box/Tube lid. It is then filled with fluid and sends the signal through the hull. This method was built into the boat when I brought it new back in 2001 and is still being used today in there latest models.
Its a bit late to head home early.
mussels
Date Joined: 06/10/08
wet box
straight water is fine, just add a drop of coolant as this stops the grime from building up.
roberta
Date Joined: 08/07/08
or straight pine-o-clean works in hubbie's wetbox
SPEWIE LEWIE .. Ginger Tablets Rock
Cockburn Power Boat Member
Ginger Tablets Rock
HuggyB
Date Joined: 03/08/08
when I enquired
they said you can basically fill it with anything. Some suggestions I got was olive oil, peanut oil, distilled water, glycerine, transmission oil and so on.
If it was me, I'd probably go glycerine. But thats just me
Dazza
Date Joined: 25/09/07
I
ive been running water in mine for last 4 years its all good i was told under no circumstances put oil in, i have a bung on the top of it, made it myself so i get it full to the top so there is no movement and less bubbles, i get a good pic at four hundred meters havent been deeper yet.
All your gyprock needs
wadetolley
Date Joined: 27/06/08
some info
Check out this link for some info mate!
http://www.thefishinhub.com.au/forum/viewtopic.php?t=1605&start=10&sid=5b5590297c71d40da0745d3a837c9023
IF YOU EVER NEED A LIMOUSINE...CALL LAKES LIMOUSINES BALLAJURA
MOBILE 0416341256 OR PH 92496113
jersey
Date Joined: 12/06/08
KY
I have found works well but for a defferent box I think jersey
out wide
Date Joined: 30/12/08
pine-o-clean
Pine-o-clean in a wet box. I dont think my wife would like that .lol
REDBALLS
Date Joined: 29/10/08
Oil is the go just depends
Oil is the go just depends on the thickness!
Thin oil like has been mentioned and is the go so just ask the guys at taylor marine!
Blank Cheque
Thanks all for your input
Some may recall my post earlier asking if anyone else has had trouble with Lowrance transducers.
Well the story is that I am now on my 3rd transducer, the last one only lasting 12 months and the unit has done very little work even though it is about 7 y/o.
After speaking with Navco they advised me that they have changed the resign in the latest transducers.
I have run cooking oil in mine since day one. Last time I replaced the transducer I noticed that a gum like substance had built up around the joins in the resign, hence my enquiry into this subject.
I think its best I go away from the oil and now have a few other options to try.
Thanks again
Garry
Cooking oil isn't a
Cooking oil isn't a non-drying oil and that would be the problem with it going gummy I guess.
