90 vro v4 johnson running hot
Submitted by MetroMako on Sun, 2013-06-02 10:02
gday i have just purchased a boat with a v4 vro johnson 90.
the motor starts and runs fine but overheats with alarms going off.
it has water coming from telltale and lots of compression, any suggestions and what i could be up against
would be helpful. thnks.
barneyboy
Date Joined: 08/01/09
with any luck
for your sake it may only be the thermostat. Best bet is to take it out and see if it is still working.
FEEEISH ONNN!!!
greasemonkey
Date Joined: 08/05/09
more info
Hey mate , a little more info might help us help you .
Are you sure its a overheat alarm not a oil flow/level alarm , if so what conditions cause the alarm to sound ?
If it is overheating can you feel the heads and figure out which side is hot .
JOEL
