4 strokes are 4 strokes at the end of the day. You’ll probably even find that the “genuine” engine oil, is nothing more than standard engine oil rebottled.
But I personaly like to go to the best quality , usually synthetic, oils. Most motors are repurposed car motors anyway. I use car oil filters too when they fit.
Really only the Hondas that are car engines as far as I know.
Suzies, Yams and Mercs are purpose built Problem with car engines is the flywheel is on the wrong end for the usual outboard layout and the crankshafts arent strong enough to do both.
Oils-I just use good quality car oil 10W-40 in mine.
The advertising blurb will tell you stuff like "increased protection from salt water corrosion..."
At the end of the day, if the engine oil and seawater are coming in contact you have a way more serious problem than oil brand will fix
A marine engine spends much more time at high rpm and under a heavy load, so its oil is more prone to shearing. Other additives, That's why a lab certifies that marine oil meets the minimum FC-W spec.
The cost is not much more, a mineral oil will do the job, synthetics just last longer
"These criteria include bench tests for viscosity, corrosion, filter plugging, foaming and aeration. In addition, the oil must successfully pass a 100-hour general performance engine test."
Which is much the same as any good auto oil anyway except it needs to demonstrated to the NMMA (and pay a fee no doubt)
What Wangler said is spot on... Oils aint oils. I certainly wouldn't be putting car engine oils into my outboards look at the specs required for an outboard and you won't find those specifications available in a car oil bottle.
Cheers guys. I put outboard oil in it. Stuff all difference in price anyway. I will say that the fuel filter price shocked me though. $52 for the smallest filter I have ever seen! Jeez they don't miss ya
scano
Date Joined: 31/05/07
Sure can
marrisy
Date Joined: 08/09/11
Agree with you.
oils
Jadeo
Date Joined: 08/06/15
Cheers fellas
i kind of figured that. Just needed someone else's thoughts.
wangler
Date Joined: 26/04/08
I suppose you can
Dougie
true that
but looking at the specs it lists
Sulo
Date Joined: 13/08/11
aaasnapper
Date Joined: 15/01/10
I was told 4 stroke outboard
I was told 4 stroke outboard engines are based on motorcycle engines. With regard to oils it needs to meet the manufacturers engine specifications.
null
Coastrunner
Date Joined: 25/10/14
Outboards might share some technology with bikes and cars
But its a big stretch to say a 200Hp Suzi is based on a GSXR donk, totally different animals.
Synthetic outboard oil in my motor.
Jadeo
