mercury 15hp two stroke starting problems
Gday Guys
I have just bought a savage snipe with a 15hp merc 2 stroke (2003). the motor was running fine yesterday and did half a tank ,starting first pull everytime! I was giving it 2 pumps on the bulb with the prime pulled out then on starting/firing pushing it in on initial start and then just one pull it would start(no priming). when i came home i took the cover off and checked the plugs which were only hand tight. i set the gaps to 1mm and retighened them. I cleaned the fuel filter out and changed the oil in the leg. It will fire up with prime/choke out then ill push it in and will run for 5 seconds then cut out!? the fuel is a week old and the motor made good power on the ocean. any ideas please ?? ive checked the tank breather and its clear!
12 hours 40 min ago
13 hours 37 min ago
13 hours 43 min ago
19 hours 10 min ago
1 day 15 hours ago
2 days 8 hours ago
2 days 13 hours ago
3 days 1 hour ago
3 days 13 hours ago
3 days 13 hours ago
