Help Targeting Dhu's
Submitted by Fisherman2804 on Wed, 2021-11-17 20:26
Gday,
Im chasing some advise on trying to target my first legal Dhu. Me and my dad have had the boat out many times throught last season and the season before but caught absolutly nothing. The whole season we got 1 legal pinkie and 3 breaksea. Been launching at freo and fishing as far out as the 60-70 meter mark behind rotto. Not asking for spots as i know they are hard to come by(But if anyone is happy to share i would be more than greatful) just trying to figure out best baits, rigs, what to look for on the sounder ect as we have tried everything we know for 4/5ths of bugger all over the last couple of seasons
Any advice is much appreciated
Well if you've caught
Well if you've caught Breaksea you're on the right kind of ground, depth sounds ok you honestly just need some luck. Look for hard flat coral that's where I've caught most my bangers. And mix it up, biggest Dhue I've caught was on a Mulie.
Try jigs as well as bait. Don't give up it will happen.
TorquenFish
Date Joined: 30/12/12
Small hard lumps (fish stuff
NORUN NOFUN
Date Joined: 15/08/11
I used to target Dhuie's out
I used to target Dhuie's out in the deeper grounds off Mindarie, but have found way more reliable and consistent catches in the 6 to 10mtr range out of Mindarie and really not that far out.
I change my spots each trip and will usually anchor off to the side of a non descript simple lump or drop off.
Burley pretty hard to start and if the skippy come in pretty quickly I will taper off and use the berley basket on the bottom and use that pretty hard.
I like a change of tide that happens just after dark and will usually coincide everything i do around a change of tide, I can kick back for three hours and the bite usually only happens for 10mins and maybe another hour after that I will get another 5min bite. I very rarely get fish every 10 or 15 minutes so it's imperitive I have everything setup correctly for that quick bite time.
I always use fresh squid that I catch at Obstacle before I head out and setup, I use whole squid unweighted with the hooks berried (just my preference), if there is a current I will use a pretty small ball sinker to get past any annoying skippy, it is really easy to tell a Dhu bite from a snapper and tend to let them have a little run before I set the hooks - Dhuie's tend to mouth a bait and snapper grab and run that I have found in shallow water.
I never leave the baits on the bottom as this keeps the unwanted species to a minimum and usually set at around 1 to 2 mtrs off the bottom depending on current - some days the current will just throw everything out the window, so adapt to it.
That's about it, you can use this technique anywhere along the coast and adapt to your style.
I also tend to find the closer I am to a lump I will get dhuie's and the snapper will tend to be in the sand.
Hope this helps
Scotty
rob90
Date Joined: 06/02/13
Got it dialled by the sounds
Got it dialled by the sounds of it! Great inshore advice. I'll add to that and say 5in placcies and just hop from lump to lump giving each one 10 or so casts in different directions, most ledges are on the sw side of a lump so focus on that. If there is a dhu there he'll eat if not move on. If your in a boat keep someone at the wheel to try keep the boat steady and cast into the lump. Saves dropping and pulling the pick 100 times a day.
Messiah
Date Joined: 19/05/13
Without knowing your
Without knowing your sounder:
http://fishwrecked.com/forum/587-tm260-dhu-shot-50m
Same as you, it took me years to come back with something decent. Now I've (semi) mastered dhufish ID on the sounder and jigging, I can't catch much else!! I get the odd pinky, but it's dhu or bust on the jigs I use.. Oh Sgt Bakers, I get them.... And sambos.. dammit, sharks too..... And tuna, but them only on blue and silver jigs mid water on the way up!!
For me I fish the sounder. I don't do long drifts, I just drop on the spot. Give it 2 or 3 drifts then move on if I get nothing..
little johnny
Sounder the main
Thing in my books. Doesn’t mater to a degree what type. Once you learn to read and use it. Fish is the easy bit
NORUN NOFUN
Great advice by Rob and
Great advice by Rob and should have mentioned the placcies, soft plastics can be a hell of alot more fun and just require patience and persistence but the hookups are ALOT of fun.
Jackfrost80
If you see a 5m Seafarer then
If you see a 5m Seafarer then avoid the ground that boat is working
